Installing plex issues
Deanmrd
Install
Error: plexfiles had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped plexfiles due to DHCP failure Partial plugin destroyed
Step 1 remove the realtek nic, step 2 why do you have a /24 and a /32. That seems crazy to me. I would reset everything
not sure as my subnet is 255.255.255.0 should be 24
when trying to install plex
Deanmrd
Realtek is part of the motherboard why is it working ok outside of the jail?
Redcoat
Is the DHCP server function disabled in your router configuration?
Redcoat
Realtek nic's are noted to have problems with FreeNAS
Redcoat
The pool doesn't have much to do with this... so "yes".
Do you have any active jails?
Deanmrd
no, it enabled it disabled on the one in the living room as I use that as a hub the Asus assigned the IP address.
Deanmrd
yes. this is not because I assigned my own FreeNAS IP address? DHCP is not on in the main ip config
Redcoat
yes. this is not because I assigned my own FreeNAS IP address? DHCP is not on in the main IP config
I'm having trouble understanding what you wrote.
I am assuming your gateway is a router (Asus?). Is its DHCP server function active?
Deanmrd
yes active on the asus router,
On the FreeNAS install I chose to assign my own FreeNAS IP is that anything to do with the issue here?
Redcoat
No, should not be.
Do you have any other jails besides the plex attempt?
Redcoat
OK, so go into the current plex jail and delete it, leaving you with no jails.
Deanmrd
when DHCP is ticked
plexserver had a failure Exception: RuntimeError Message: + Acquiring DHCP address: FAILED, address received: 0.0.0.0/8 Stopped plexserver due to DHCP failure Partial plugin destroyed
When is unticked and I set the ip and mask
Error: Jail: plexserver has a missing configuration, please check that the dataset is mounted.
Redcoat
All that from deleting the existing jail?
SweetAndLow
Sweet'NASty
You have multiple routers in your network? You probably have double nat and that's messing things up. Only 1 router on a network unless you know what you are doing.
Set your jail ip with a static IP and all the other networking fields like you did for freenas.
Deanmrd
After deleted the jail and tried to install plex from plugins
Install
Redcoat
Over to you, Sweet... two coaches isn't going to work here, I fear. I'm out.
Deanmrd
Set your jail IP with a static IP and all the other networking fields like you did for freenas.
DHCP and nat are disabled. the main ip changed as to 192.168.1.2 <gateway for that router.
