I'm trying to install FreeNAS on a new setup is just built.
I created a boot-stick with the current version using Win32DiskManager.
When i try to boot from the usb stick I get into the selection menu where I can choose what I want to do.
After pressing Enter the installer loads a bit and then stops working at all just writing "Booting...".
Waiting for 5 minutes does not change anything.
My hardware:
ASRock Q1900B-ITX
16GB Corsair VS-Series DDR3 SO-DIMM Kit
Samsung SSD
I read that there were some problems with the Bay Trail chipset but it stated that this was fixed from FreeNAS version 11 and up.
Maybe anyone has an idea.
Thanks for you help!
My hardware:
ASRock Q1900B-ITX
Samsung SSD
