I have a new HP DL385 Gen 10+ server equipped with 2 EPYC CPUs, 256GB RAM. Also has an E208i SAS controller installed
No matter what I do, I cannot get the FreeNAS installer to see the drives attached to the SAS controller.
If I install to a USB drive, FreeNAS boots, and it sees all the drives attached to the controller. It's almost like the smartpqi kernel driver is not compiled into the kernel used by the installer, but IS compiled into the one used to actually run FreeNAS.
I have 2 SATA SSDs connected to the array that I would like to install to as a mirrored set, but nothing I do allows me to see DA0 and DA1 (or any other drive connected to the SAS controller). I can see my add-in NVME cards, but those are not for boot, but for Tier1 storage.
Another issue that might be related: When I install to USB and try to update to TrueNAS 12 Core (beta) the update fails and it will no longer boot.
