Installed apps not working after reboot
goshku
I am using TrueNAS Scale (TrueNAS-SCALE-22.12.0). After reboot - all my apps stopped working. After trying to reinstall traefik - its working normally, but all other are still not working. This is a second time that i am getting that experience, but first time was only plex and i just reinstall it and everything was like normal.
But maybe its not normal after every reboot to reinstall everything and doing all setup of all apps again.
And i looking for some help :D
Greetings
goshku
Reinstalled some of apps because i need them right now. But left plausible (there is so much logs there and i dont want to lost them)
After running this command -
k3s kubectl get pods -A
I am receiving this
goshku
When i am trying to edit/save app, i am receiving:
[EFAULT] Failed to update chart release: Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 426, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 461, in __run_body
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf
    res = await f(*args, **kwargs)
  File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf
  File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py", line 553, in do_update
    await self.middleware.call('chart.release.helm_action', chart_release, chart_path, config, 'update')
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1306, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1266, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1169, in run_in_executor
  File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/helm.py", line 44, in helm_action
    raise CallError(f'Failed to {tn_action} chart release: {stderr.decode()}')
middlewared.service_exception.CallError: [EFAULT] Failed to update chart release: Error: UPGRADE FAILED: another operation (install/upgrade/rollback) is in progress
