Installation question
jouko45672
Tried to install TrueNas core 13 to VMware ESXi 7.02. I have HP Proliant ML110 server with 4 disks. disks are raid1 on 2 datastores.
My plan is to install TrueNas to DS1 and use DS2 as TrueNas datadisk. I can install TrueNas ok, but i don't see any disks on TrueNas ?
NugentS
If you mean what I think you mean.
No - Just no - don't do it.
There are resources in this forum that say how to do virtualisation, if you really have to
jouko45672
Problem solved, it was issue on ESXi 7.0. Another disk has to be manually added with vmkfstools command.
