Input on my first Freenas Server build...
benraines815
First of all.. Great forum... The knowledge and info is very useful and informative.
So I've been reading and searching the community forum and I think I'm about ready to finish my purchase...
I'm going with a Supermicro X9DRL-3F 2 socket motherboard for a few reasons...
Price and I want to run VMs on it using the FreeNAS x10 bhyve hypervisor.
This will be for home use. (primarily files, media, light streaming and VMs)
I have:
Case: Silverstone CS380 ATX
PSU: Seasonic X series 650watt
HDD: 7 WD Red Drives
Looking at below for the rest...
Mobo: Supermicro X9DRL-3F-O Dual LGA2011/ Intel C606/ DDR3/ SATA3/ V&2G
$299.00
CPU: CM8062101082713 1 INTEL XEON E5-2670 8 CORE 2.60GHz 20M 8GT/s 115W PROCESSOR
$88 (hoping 1 CPU we'll be ok in the beginning)
RAM: 16GB 2x16GB DDR3 Memory PC3-10600R ECC REG DIMM 240-Pin 1333MHz RAM Memory
$34.00 (I'll start with 32gb and grow from there..)
I think all I need now is to get a thumbdrive for FreeNAS, heatsinks, SLOG device, ups and I'm good to go for the install...
Looking for input on the hardware I have chosen.. (I did my best to look at mobo manuals, specs, requirements and reading through forums)
Any input on a heatsink??
wblock
Documentation Engineer
I'm skeptical about the need for a SLOG device on this.
As far as heatsinks, I have personally replaced the stock one included with a Xeon E3 with a Hyper 212 Evo and found no difference. Have not tried the E5 processors, though.
SweetAndLow
Sweet'NASty
I agree that you probably don't need the slog device. Get any quality heatsink you want they will all cool just fine. If you are looking at getting a dual socket system just for vm's I think you need to get way more memory and start with 16GB or 32GB dimms.
melloa
RAM: 16GB 2x8GB DDR3 Memory PC3-10600R ECC REG DIMM 240-Pin 1333MHz RAM Memory
Did you mean to say 4x8GB? I read 32GB as starting ...
benraines815
Thanks. I'm actually starting out with 32gb 2 16gb sticks. I goofed up on my message. I'm just starting with 32gb in the beginning and will add another 32 or 48gb later.
I just wanted to make sure the hardware I picked out would work with freenas
Thanks.
I'm just starting out
benraines815
Heatsink ordered.. One down many to go....
Funny, I'm re-checking my list to confirm compatibility..
I thought my MOBO had to have a Xeon 2600 V2 after looking at some specs..
So I started searching for the V2 on ebay and found a 10 Core at a better price..
Turns out my MOBO supports the 2600 and the 2600 V2.. Oh well.. I like the 10 core which is $20 cheaper and a year newer...
melloa
Are you sure you need all that CPU power? Usually is memory that will hold you up ... That picture is of an i3 with 24 GB RAM, running 6 VMs. I've been moving my ESXI from server to server here at home to see what I really need: From an old 2950, to an Intel S5000 dual xeon x5450 3 GHz, and today moved to that i3 just for test. The pick in CPU utilization you will see was when I was creating a linux VM and doing a huge update to it and, at the same time, I'm watching x-files on my Plex :)
Let me know where you land as I'm also trying to build a new server, but for virtualization, as my FreeNASes are all set on two separated, dedicated, boxes.
