It's well known that TrueNAS Scale can't control the LED on something like an R720XD. However, that doesn't mean it has to let the user fly totally blind.
While sas2ircu will fail when one tries to use locate, the information provided it's display command is good to identify which slot/bay a drive is in. It would seem to be a major quality of life improvement for TrueNAS to be able to expose this via the UI to administrators.
Additionally, I have SAS drives that seem to be problematic "serial number" wise (i.e the serial number reported by normal tools (sas2ircu does report what is printed) doesn't reflect what is printed on the drive). However, they also have a WWN printed on them that is accurate to what linux detects AND what sas2ircu shows. It be nice if a) the UI could expose the WWN for physical devices in addition to the serial # and be able to use this information to corrolate the slot/bay information I mention above.
TrueNAS could show a visual diagram that shows which drive is faulty, instead of just having to rely on guessing or a manually generated text file that has serial number to bay mappings.
thoughts?
thoughts?
