diskdiddler
- Jul 9, 2014
Hi all,
During testing, half set up a dockerVM - was running ok.
Had some issues, had to nuke the entire config, that's ok.
Imported volumes (first time I've ever done it, worked well!)
Re-created docker VM but pointed the Raw at the old file, it didn't boot up the same, it dropped to some weird shell.
Is there a process to do this so it imports it identically? Something clearly broke, possibly even over writing the old VM raw file the first time I started it?
Thoughts?
Thoughts?
