iainc
- Aug 7, 2014
I've been running FreeNAS for a while and I haven't had any issues. It's generally sweet.
I want to add more disks and my EVGA 790i mobo only has 6 sata ports. So I added a RocketRaid 1820A. It's just a controller - no hw RAID.
If I export and move the drives over to the RocketRaid, ZFS doesn't recognize them. camcontrol devlist shows them (with slightly mangled names). zpool import does nothing. In the first listing below, one drive is still connected to the mobo and it gets found; the other four are on the RocketRaid.
I've had a poke around in the RocketRaid's boot-time config menus. Nothing seems untoward. I've had a read of the zpool import man page. I can't see an option that seems like it'd help.
Is there something I can do to kick ZFS into finding all my drives?
-Iain
And then situation normal if I reconnect all drives to the mobo and auto-import with the web interface:
-Iain
FreeBSD 9.2-RELEASE-p3 (FREENAS.amd64) #0 r262572+38751c8: Thu Mar 20 21:13:02 PDT 2014
[root@freenas] ~# zpool status
pool: HomeData
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0h2m with 0 errors on Sun Jun 8 00:02:52 2014
NAME STATE READ WRITE CKSUM
HomeData DEGRADED 0 0 0
mirror-0 DEGRADED 0 0 0
gptid/a794e0e3-bbf4-11e3-9b41-00044b16c3a2 ONLINE 0 0 0
5726468597135835663 UNAVAIL 0 0 0 was /dev/gptid/a806c886-bbf4-11e3-9b41-00044b16c3a2
errors: No known data errors
[root@freenas] ~# camcontrol devlist
<ST3320620AS 3.AAJ> at scbus6 target 0 lun 0 (ada0,pass0)
<ST332062 0AS 3.AA> at scbus9 target 0 lun 0 (da0,pass1)
<Hitachi HDT721010SLA ST6O> at scbus9 target 1 lun 0 (da1,pass2)
<ST1000DL 002-9TT153 CC32> at scbus9 target 2 lun 0 (da2,pass3)
<ST1000DL 002-9TT153 CC32> at scbus9 target 3 lun 0 (da3,pass4)
< USB DISK 2.0 PMAP> at scbus14 target 0 lun 0 (pass5,da4)
[root@freenas] ~# zpool import
[root@freenas] ~#
<ST1000DL002-9TT153 CC32> at scbus3 target 0 lun 0 (ada0,pass0)
<Hitachi HDT721010SLA360 ST6OA31B> at scbus4 target 0 lun 0 (ada1,pass1)
<ST3320620AS 3.AAD> at scbus5 target 0 lun 0 (ada2,pass2)
<ST3320620AS 3.AAJ> at scbus6 target 0 lun 0 (ada3,pass3)
<ST1000DL002-9TT153 CC32> at scbus7 target 0 lun 0 (ada4,pass4)
< USB DISK 2.0 PMAP> at scbus14 target 0 lun 0 (pass5,da0)
pool: HomeData
state: ONLINE
scan: resilvered 580K in 0h0m with 0 errors on Mon Jul 14 12:12:45 2014
HomeData ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/a806c886-bbf4-11e3-9b41-00044b16c3a2 ONLINE 0 0 0
pool: WorkData
state: ONLINE
scan: scrub repaired 0 in 1h28m with 0 errors on Sun Jun 8 01:28:03 2014
WorkData ONLINE 0 0 0
gptid/dcd0877e-bbf4-11e3-9b41-00044b16c3a2.eli ONLINE 0 0 0
gptid/dd8791d7-bbf4-11e3-9b41-00044b16c3a2.eli ONLINE 0 0 0
pool: softservZFS
state: ONLINE
scan: scrub repaired 0 in 3h20m with 0 errors on Sun Jun 8 03:20:19 2014
softservZFS ONLINE 0 0 0
gptid/5e8ab0dc-c15c-11e3-8a08-00044b16c3a2 ONLINE 0 0 0
