maclark7029
- Apr 6, 2014
Well it has finally happened - I apparently have had a hard fail. I have nine (9) drives in the volume. How do I determine which physical drive has to be replaced? After I replace the drive, what should I do?
Thanks,
Mike
Here's the output of zpool status
[root@server] ~# zpool status
pool: Server
state: DEGRADED
status: One or more devices has been removed by the administrator.
Sufficient replicas exist for the pool to continue functioning in a
degraded state.
action: Online the device using 'zpool online' or replace the device with
'zpool replace'.
scan: scrub repaired 0 in 20h20m with 0 errors on Thu May 1 22:20:17 2014
NAME STATE READ WRITE CKSUM
Server DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/81229daf-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
2640467949715332454 REMOVED 0 0 0 was /dev/gptid/81833b72-a7d3-11e3-b8dd-6cf04961bcb5
gptid/823997ea-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/83025add-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/83c44d93-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/8487e127-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/85333f83-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/85f22ac2-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
gptid/86a7cd3e-a7d3-11e3-b8dd-6cf04961bcb5 ONLINE 0 0 0
errors: No known data errors
Here's the output of camcontrol devlist
[root@server] ~# camcontrol devlist
<WDC WD20EARX-008FB0 51.0AB51> at scbus1 target 0 lun 0 (ada1,pass1)
<WDC WD20EFRX-68EUZN0 80.00A80> at scbus4 target 0 lun 0 (ada2,pass2)
<WDC WD20EFRX-68EUZN0 80.00A80> at scbus5 target 0 lun 0 (ada3,pass3)
<WDC WD20EFRX-68EUZN0 80.00A80> at scbus6 target 0 lun 0 (ada4,pass4)
<ST32000542AS CC35> at scbus7 target 0 lun 0 (ada5,pass5)
<Crucial CT120M500SSD1 MU03> at scbus9 target 0 lun 0 (ada6,pass6)
<WDC WD20EARX-00PASB0 51.0AB51> at scbus9 target 1 lun 0 (ada7,pass7)
<WDC WD20EARX-00PASB0 51.0AB51> at scbus10 target 0 lun 0 (ada8,pass8)
<WDC WD20EARX-008FB0 51.0AB51> at scbus10 target 1 lun 0 (ada9,pass9)
Thanks,
Mike
pool: Server
state: DEGRADED
degraded state.
'zpool replace'.
