Hi There,
I have managed to bring back my pool thanks to this excellent forum.
I also found a way to Re-import a jail
 I think it isn't correct anymore for the new 8.3.1 release p2 because there's no button ...unless William was referring to a saved config file?? witch we lack of course
I also found thisto bring back my jail...
I done step 1 from it but got 2 errors
Should I be concerned...Is there a bettere way to Re-Import a existing jail....
Thanks for reading
Guy Forssman
http://forums.freenas.org/showthread.php?8670-import-a-jail
I also found this
http://groovy-skills.com/FreeBSD/2012/09/16/bestehende-freenas-plugins-jail-importieren-nach-factory-reset/ In FreeNAS Version 8.2 scheint die Möglichkeit zum Import einer bestehenden Plugins-Jail zu fehlen. Mit wenig Aufwand kann man dennoch eine bestehnede Jail wieder zum Einsatz bringen: Sicherstellen, dass der Plugins-Dienst inaktiv ist (Services > Plugins > Management > Settings) Bestehende Jail umbenennen mv /mnt/volume1/jail/plugins-jail /mnt/volume1/jail/plugins-jail_backup Eine neue Plugins-Jails via WebUI erstellen (Services > Plugins > Management > Settings) Speicherort: /mnt/volume1/jail/ Name: plugins-jail Die neu erzeugte Jail mit der der ursprünglichen vertauschen mv /mnt/volume1/jail/plugins-jail /mnt/volume1/jail/plugins-jail_pristine mv /mnt/volume1/jail/plugins-jail_backup /mnt/volume1/jail/plugins-jail Den Plugins-Dienst via WebUI starten (Services > Control Services)
[root@DGCPOST002] /mnt/DGCOM-Music/jail/software/var# mv /mnt/DGCOM-Music/jail/software /mnt/DGCOM-Music/backup mv: /mnt/DGCOM-Music/jail/software/var/run/logpriv is a socket (not copied). mv: /mnt/DGCOM-Music/jail/software/var/run/log is a socket (not copied). [root@DGCPOST002] /mnt/DGCOM-Music/jail/software/var#
Thanks for reading
Guy Forssman
