cruzmiester
 - Aug 31, 2012
I set up a test FreeNAS system using UFS files system because I was not able to make some older Linux systems read the FreeNAS ZFS file system. I was able to connect some 32 bit / 64 bit Linux system and a Windows 7 System using the iscsi service.
Can anyone recommend a solution, even if it's a 3rd party solution, to encrypt the data that would be supported by reasonably older and newer Linux & Windows OS systems.
however whimsical the Home Depot solution I read on this forum is, it's not all that practical or wise considering that today in many small companies their data is probably their most valuable asset, not protecting it is incredibly naive.
Thanks for the help!!!
Carlos
Carlos
