Idrive script on TrueNAS Scale Bluefin - package installation
GabrieleMax
Hi guys,
I found, before post this, another page about Idrive service https://www.truenas.com/community/t...lling-idrive-scripts-on-truenas-scale.106602/ but it didn't help me... :\
This https://ibb.co/nLNJvxS is the link about what I have, basically I should install needed packages, I'm a Debian user since years and years but I'm a newbie on TrueNAS Scale so I'd like to do the right steps or better I'd like to know which is the best way to load packages if apt aptitude and apt-get are not avalaible!
I also searched on the web to find something who could help me but... nothing!
Thanks for your assistance and have a nice day! :)
GabrieleMax
The thread you linked to has the name of the image and links to the instructions for how to use the Launch Docker Image option... what's not helpful about that?
You're using an appliance and as stated in the linked thread, no packages should be installed directly on it, so containers are the answer.
GabrieleMax
Thanks for your reply but before it... I'm sorry for the stupid question, I wrote the question and at the same time the answer! LOL! o_O
I never user Docker and this is the good time to do it! :smile:
Now I should study it to understand:
1) When I'll reboot the NAS docker will be loaded? When I uses Jail in TrueNAS core I set it to automatically load at startup.
2) How I could set the backup for the entire pool? Maybe the IDrive scripts will help me or maybe I should manually mount it...
Regards.
GabrieleMax
Yes.
Set whatever you want to be visible to the container in the Storage section as a host path. I doubt this will allow properly for the backup of an "entire pool", but you should be able to cover the data that's important.
Be aware about the SMB sharing restrictions and containers... see the SMB section here https://www.truenas.com/community/threads/bluefin-recommended-settings-and-optimizations.106034/
GabrieleMax
Thanks for yuor reply! :)
I choosed the edit feature of the Docker image and I found:
-Host Path Volumes
-Memory Backed Volumes
I added the path /mnt/POOL01/Dataset01/veeam365/Veeam/Backup365 in the first menu and it works but tomorrow I'll search what the second feature means! :)
GabrieleMax
