nanopete
- Nov 20, 2014
Where do I start, I want to learn
Docker/k3s so I can use/run my own customized debain/ubuntu images in Truenas Scale, so I can work similarly to what I was able to with iocages in Core.
I feel Truecharts and the GUI of Truenas Scale is a bad entry to this.
I thought I would start here https://docs.docker.com/get-started/
Can I use and learn docker/k3s directly in Truenas Scale cli or is there some subtle differences in the implementation of them that would make that a bad idea / I should know of.
Is there a good docker/k3s guide, specifically for using docker/k3s inside Truenas Scale I should be aware of?
Thank you for your advise!
I hope I can level up and end up being of help instead of requiring help.
