(humble) Request: Installation guide for Deluge in a jail on 9.10 (current stable build)
Nucshuco
  • sickrage.txt
  • couchpotato.txt
NigelNoFriends
save it
service deluged start
I got to that spot and it printed this
root@deluge:/usr/local/etc/rc.d # service deluged start
/usr/local/etc/rc.d/deluged: startup: not found
/usr/local/etc/rc.d/deluged: 20: Syntax error: ")" unexpected
root@deluge:/usr/local/etc/rc.d # zsh: killed     jexec 10 tcsh
freenas#
Hoever, that's based on eventually getting pkg to install (well before you posted it was working again above), so maybe it was just a bad install - I'll delete the jail, do another pkg install now and then attempt your steps again.
Nucshuco
Don't think you pasted the startup script right.
NigelNoFriends
default port for GTK user interface : 58846
OK - did some googling and found out how to access the GTK UI. Once I did, it seemed to messup the connection Sonarr had with the webUI, so I killed the jail and did a fresh install.
Only think I am working on now is figuring out how to get Deluge to download files and set default permissions on the to 777. I am using root user for deluge, but it still seem to dl files as RWX-R-R.
Sonarr also doensn't seem to be able pickup and remove torrents from Deluge on completion - I have a feeling this has something to do with permissions, but can't be sure.
Regardless - Deluge is working. Thanks again for all your help!
LGSONE
@Nucshuco , your guide is the one that finally worked for me to get this up and running. The only outstanding item to my install is the Deluge plugins. I have read needing to add the .python-eggs folder. Tried this but no change. Is there something I'm missing here. I noticed some of the folder layouts are different on this install compared to some other guides so I wonder if the location and a conf setting needs to be updated. Your help would be fantastic. I had this running in a docker without this issue, rolled back to 9.10 and am now on 11 nightlies with this as the only item I have yet to work thru.
LGS
LGSONE
