Hello everyone,
I just installed FreeNAS 9.3 on a backblaze with two Rocket 750 cards and 45 x 4TB HDDs. I'm unable to start S.M.A.R.T. Which fails complaining about disk 21 on the second hptnr controller:
Dec 18 20:07:03 bbz01 notifier: Starting smartd.
Dec 18 20:08:02 bbz01 smartd[12033]: Unable to register ATA device /dev/hptnr [hpt_disk_2/21/1] at line 48 of file /usr/local/etc/smartd.conf
Dec 18 20:08:02 bbz01 smartd[12033]: Unable to register device /dev/hptnr [hpt_disk_2/21/1] (no Directive -d removable). Exiting.
Dec 18 20:08:02 bbz01 root: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
Dec 18 20:08:02 bbz01 notifier: /usr/local/etc/rc.d/smartd: WARNING: failed to start smartd
[root@bbz01] ~# tail -5 /usr/local/etc/smartd.conf
/dev/hptnr -d hpt,2/17 -a -n sleep -W 0,0,0 -m me@me.com -s L/(01|02|03|04|05|06|07|08|09|10|11|12)/../(6)/..
/dev/hptnr -d hpt,2/18 -a -n sleep -W 0,0,0 -m me@me.com -s L/(01|02|03|04|05|06|07|08|09|10|11|12)/../(6)/..
/dev/hptnr -d hpt,2/19 -a -n sleep -W 0,0,0 -m me@me.com -s L/(01|02|03|04|05|06|07|08|09|10|11|12)/../(6)/..
/dev/hptnr -d hpt,2/20 -a -n sleep -W 0,0,0 -m me@me.com -s L/(01|02|03|04|05|06|07|08|09|10|11|12)/../(6)/..
/dev/hptnr -d hpt,2/21 -a -n sleep -W 0,0,0 -m me@me.com
However, there is no such disk on hptnr controller, the disk ID jumps from 19 to 23
dmesg | grep 'disk probed'
hptnr: [02:00 15] disk probed (spinup mode: 1).
hptnr: [02:00 16] disk probed (spinup mode: 1).
hptnr: [02:00 17] disk probed (spinup mode: 1).
hptnr: [02:00 18] disk probed (spinup mode: 1).
hptnr: [02:00 19] disk probed (spinup mode: 1).
hptnr: [02:00 23] disk probed (spinup mode: 1).
Here is the output of smartctl for disk 21
[root@bbz01] ~# smartctl /dev/hptnr -d hpt,2/21 -a
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p5 amd64] (local build)
Read Device Identity failed: Unknown error
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
[root@bbz01] ~#
And here is the output for smartctl for disk 24
[root@bbz01] ~# smartctl /dev/hptnr -d hpt,2/24 -a
Device Model: HGST HUS724040ALA640
Serial Number: PN2334PCGTY11B
LU WWN Device Id: 5 000cca 24ccb55e5
Firmware Version: MFAOAA70
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
...<snip>...
camcontrol also shows incorrect drive ID
[root@bbz01] ~# camcontrol devlist
<WDC WD5000LPVX-22V0TT0 01.01A01> at scbus0 target 0 lun 0 (pass0,ada0)
<WDC WD5000LPVX-22V0TT0 01.01A01> at scbus1 target 0 lun 0 (pass1,ada1)
<HPT DISK 0_0 4.00> at scbus7 target 0 lun 0 (pass2,da0)
<HPT DISK 0_1 4.00> at scbus7 target 1 lun 0 (pass3,da1)
<HPT DISK 0_2 4.00> at scbus7 target 2 lun 0 (pass4,da2)
<HPT DISK 0_3 4.00> at scbus7 target 3 lun 0 (pass5,da3)
<HPT DISK 0_4 4.00> at scbus7 target 4 lun 0 (pass6,da4)
<HPT DISK 0_5 4.00> at scbus7 target 5 lun 0 (pass7,da5)
<HPT DISK 0_6 4.00> at scbus7 target 6 lun 0 (pass8,da6)
<HPT DISK 0_7 4.00> at scbus7 target 7 lun 0 (pass9,da7)
<HPT DISK 0_8 4.00> at scbus7 target 8 lun 0 (pass10,da8)
<HPT DISK 0_9 4.00> at scbus7 target 9 lun 0 (pass11,da9)
<HPT DISK 0_10 4.00> at scbus7 target 10 lun 0 (pass12,da10)
<HPT DISK 0_11 4.00> at scbus7 target 11 lun 0 (pass13,da11)
<HPT DISK 0_12 4.00> at scbus7 target 12 lun 0 (pass14,da12)
<HPT DISK 0_13 4.00> at scbus7 target 13 lun 0 (pass15,da13)
<HPT DISK 0_14 4.00> at scbus7 target 14 lun 0 (pass16,da14)
<HPT DISK 0_15 4.00> at scbus7 target 15 lun 0 (pass17,da15)
<HPT DISK 0_16 4.00> at scbus7 target 16 lun 0 (pass18,da16)
<HPT DISK 0_17 4.00> at scbus7 target 17 lun 0 (pass19,da17)
<HPT DISK 0_18 4.00> at scbus7 target 18 lun 0 (pass20,da18)
<HPT DISK 0_19 4.00> at scbus7 target 19 lun 0 (pass21,da19)
<HPT DISK 0_20 4.00> at scbus7 target 20 lun 0 (pass22,da20)
<HPT DISK 0_21 4.00> at scbus7 target 21 lun 0 (pass23,da21)
<HPT DISK 0_22 4.00> at scbus7 target 22 lun 0 (pass24,da22)
<HPT DISK 0_23 4.00> at scbus7 target 23 lun 0 (pass25,da23)
<HPT DISK 0_0 4.00> at scbus8 target 0 lun 0 (pass26,da24)
<HPT DISK 0_1 4.00> at scbus8 target 1 lun 0 (pass27,da25)
<HPT DISK 0_2 4.00> at scbus8 target 2 lun 0 (pass28,da26)
<HPT DISK 0_3 4.00> at scbus8 target 3 lun 0 (pass29,da27)
<HPT DISK 0_4 4.00> at scbus8 target 4 lun 0 (pass30,da28)
<HPT DISK 0_5 4.00> at scbus8 target 5 lun 0 (pass31,da29)
<HPT DISK 0_6 4.00> at scbus8 target 6 lun 0 (pass32,da30)
<HPT DISK 0_7 4.00> at scbus8 target 7 lun 0 (pass33,da31)
<HPT DISK 0_8 4.00> at scbus8 target 8 lun 0 (pass34,da32)
<HPT DISK 0_9 4.00> at scbus8 target 9 lun 0 (pass35,da33)
<HPT DISK 0_10 4.00> at scbus8 target 10 lun 0 (pass36,da34)
<HPT DISK 0_11 4.00> at scbus8 target 11 lun 0 (pass37,da35)
<HPT DISK 0_12 4.00> at scbus8 target 12 lun 0 (pass38,da36)
<HPT DISK 0_13 4.00> at scbus8 target 13 lun 0 (pass39,da37)
<HPT DISK 0_14 4.00> at scbus8 target 14 lun 0 (pass40,da38)
<HPT DISK 0_15 4.00> at scbus8 target 15 lun 0 (pass41,da39)
<HPT DISK 0_16 4.00> at scbus8 target 16 lun 0 (pass42,da40)
<HPT DISK 0_17 4.00> at scbus8 target 17 lun 0 (pass43,da41)
<HPT DISK 0_18 4.00> at scbus8 target 18 lun 0 (pass44,da42)
<HPT DISK 0_19 4.00> at scbus8 target 19 lun 0 (pass45,da43)
<HPT DISK 0_20 4.00> at scbus8 target 20 lun 0 (pass46,da44)
Please advise.
Thanks,
Roman.
[root@bbz01] ~#
...<snip>...
Please advise.
Thanks,
Roman.
