AllTheGoodNamesWereTaken
- Feb 4, 2018
Hope it FreeNASses...
Hey guys I am looking at building my second FreeNAS box and moving away from the m-itx consumer grade build that i have at the moment.
I am looking at buying a second hand server, HBA and a disk shelf.
I plan on using the drives from my current server which are 3.5" 4tb drives.
The server i am looking at buying is HP dl380 g7 or similar. Link to the server bellow.
https://www.ebay.com.au/itm/HP-DL38...451011?hash=item1c99903c83:g:pH8AAOSwiYlaH0WX
The issue with this server is that it has 2.5" drive bays so i will need to buy a HBA and disk shelf which I plan to use external SAS connectors to connect to the disks.
Does anyone have any recommendations or suggestions on a different direction I should go prior to buying the server?
Thanks for the help.
