[HowTo] Multi-Hop SSH into FreeNAS
zoomzoom
FreeNAS servers are meant to be run behind the firewall of a router, with two options to gain access to the server remotely, a VPN or an SSH multi-hop​
A Multi-Hop SSH is an SSH tunnel over WAN to the router, with a second SSH tunnel through it to FreeNAS over LAN
  • Remote device -> WAN SSH -> Router -> [multi-hop begins] -> LAN SSH -> FreeNAS
Utilizing PuTTY, the router & client profiles below will be required:
  • SFTP via pscp.exe in the PuTTY root directory
    • Add PuTTY directory to your environment path to allow access to pscp from any powershell/command terminal
      System - Advanced System Settings - Environment Variables - System Variables - Path
  • JuiceSSH [Android] automates the multi-hop by setting Connection - Advanced Settings - Connect Via to Router's Remote SSH connection
Router (your.ddns.com)
  • Edit Lines:
    • (5) "HostName"="your.ddns.com"
    • (6) "LogFileName"="C:\\Path\\To\\PuTTY\\Logs\\SSH.OpenWRT.Remote.log"
      • Log set to "All Session Output" [Session - Logging]
    • (15) "PortNumber"=dword:00000016
      • Hex value for SSH Port # [hex] 00000016 = [dec] 22
        Windows Calculator has a "Programmer" mode with hex <-> dec
    • (58) "PublicKeyFile"="C:\\Path\\To\\PuTTY\\SSHkeys\\OpenWRT.SSH.ppk"
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\SimonTatham\PuTTY\Sessions\SSH.OpenWRT.Remote]
"Present"=dword:00000001
"LogType"=dword:00000002
"LogFileClash"=dword:ffffffff
"LogFlush"=dword:00000000
"SSHLogOmitPasswords"=dword:00000001
"SSHLogOmitData"=dword:00000000
"Protocol"="ssh"
"CloseOnExit"=dword:00000001
"WarnOnClose"=dword:00000001
"PingInterval"=dword:00000000
"PingIntervalSecs"=dword:00000000
"TCPNoDelay"=dword:00000001
"TCPKeepalives"=dword:00000000
"TerminalType"="xterm"
"TerminalSpeed"="38400,38400"
"TerminalModes"="CS7=A,CS8=A,DISCARD=A,DSUSP=A,ECHO=A,ECHOCTL=A,ECHOE=A,ECHOK=A,ECHOKE=A,ECHONL=A,EOF=A,EOL=A,EOL2=A,ERASE=A,FLUSH=A,ICANON=A,ICRNL=A,IEXTEN=A,IGNCR=A,IGNPAR=A,IMAXBEL=A,INLCR=A,INPCK=A,INTR=A,ISIG=A,ISTRIP=A,IUCLC=A,IXANY=A,IXOFF=A,IXON=A,KILL=A,LNEXT=A,NOFLSH=A,OCRNL=A,OLCUC=A,ONLCR=A,ONLRET=A,ONOCR=A,OPOST=A,PARENB=A,PARMRK=A,PARODD=A,PENDIN=A,QUIT=A,REPRINT=A,START=A,STATUS=A,STOP=A,SUSP=A,SWTCH=A,TOSTOP=A,WERASE=A,XCASE=A"
"AddressFamily"=dword:00000000
"ProxyExcludeList"=""
"ProxyDNS"=dword:00000001
"ProxyLocalhost"=dword:00000000
"ProxyMethod"=dword:00000000
"ProxyHost"="proxy"
"ProxyPort"=dword:00000050
"ProxyUsername"=""
"ProxyPassword"=""
"ProxyTelnetCommand"="connect %host %port\\n"
"Environment"=""
"UserName"="root"
"UserNameFromEnvironment"=dword:00000000
"LocalUserName"=""
"NoPTY"=dword:00000000
"Compression"=dword:00000000
"TryAgent"=dword:00000001
"AgentFwd"=dword:00000001
"GssapiFwd"=dword:00000000
"ChangeUsername"=dword:00000000
"Cipher"="aes,WARN,3des,blowfish,arcfour,des"
"KEX"="dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,WARN"
"RekeyTime"=dword:0000003c
"RekeyBytes"="1G"
"SshNoAuth"=dword:00000000
"SshBanner"=dword:00000001
"AuthTIS"=dword:00000000
"AuthKI"=dword:00000001
"AuthGSSAPI"=dword:00000001
"GSSLibs"="gssapi32,sspi,custom"
"GSSCustom"=""
"SshNoShell"=dword:00000000
"SshProt"=dword:00000003
"LogHost"=""
"SSH2DES"=dword:00000000
"RemoteCommand"=""
"RFCEnviron"=dword:00000000
"PassiveTelnet"=dword:00000000
"BackspaceIsDelete"=dword:00000001
"RXVTHomeEnd"=dword:00000000
"LinuxFunctionKeys"=dword:00000000
"NoApplicationKeys"=dword:00000000
"NoApplicationCursors"=dword:00000000
"NoMouseReporting"=dword:00000000
"NoRemoteResize"=dword:00000000
"NoAltScreen"=dword:00000000
"NoRemoteWinTitle"=dword:00000000
"RemoteQTitleAction"=dword:00000001
"NoDBackspace"=dword:00000000
"NoRemoteCharset"=dword:00000000
"ApplicationCursorKeys"=dword:00000000
"ApplicationKeypad"=dword:00000000
"NetHackKeypad"=dword:00000000
"AltF4"=dword:00000001
"AltSpace"=dword:00000001
"AltOnly"=dword:00000000
"ComposeKey"=dword:00000000
"CtrlAltKeys"=dword:00000001
"TelnetKey"=dword:00000000
"TelnetRet"=dword:00000001
"LocalEcho"=dword:00000002
"LocalEdit"=dword:00000002
"Answerback"="PuTTY"
"AlwaysOnTop"=dword:00000000
"FullScreenOnAltEnter"=dword:00000000
"HideMousePtr"=dword:00000000
"SunkenEdge"=dword:00000000
"WindowBorder"=dword:00000005
"CurType"=dword:00000001
"BlinkCur"=dword:00000001
"Beep"=dword:00000001
"BeepInd"=dword:00000000
"BellWaveFile"=""
"BellOverload"=dword:00000001
"BellOverloadN"=dword:00000005
"BellOverloadT"=dword:000007d0
"BellOverloadS"=dword:00001388
"ScrollbackLines"=dword:00002710
"DECOriginMode"=dword:00000000
"AutoWrapMode"=dword:00000001
"LFImpliesCR"=dword:00000000
"CRImpliesLF"=dword:00000000
"DisableArabicShaping"=dword:00000000
"DisableBidi"=dword:00000000
"WinNameAlways"=dword:00000001
"WinTitle"="Secure Shell - OpenWRT (Remote)"
"TermWidth"=dword:00000077
"TermHeight"=dword:00000028
"Font"="Lucida Console"
"FontIsBold"=dword:00000000
"FontCharSet"=dword:00000000
"FontHeight"=dword:0000000a
"FontQuality"=dword:00000003
"FontVTMode"=dword:00000004
"UseSystemColours"=dword:00000000
"TryPalette"=dword:00000000
"ANSIColour"=dword:00000001
"Xterm256Colour"=dword:00000001
"BoldAsColour"=dword:00000002
"Colour0"="175,175,175"
"Colour1"="255,125,0"
"Colour2"="25,25,25"
"Colour3"="20,20,20"
"Colour4"="0,163,255"
"Colour5"="0,163,255"
"Colour6"="0,0,0"
"Colour7"="85,85,85"
"Colour8"="187,0,0"
"Colour9"="255,85,85"
"Colour10"="0,187,0"
"Colour11"="85,255,85"
"Colour12"="187,187,0"
"Colour13"="255,255,85"
"Colour14"="0,163,255"
"Colour15"="0,100,255"
"Colour16"="187,0,187"
"Colour17"="255,85,255"
"Colour18"="0,187,187"
"Colour19"="85,255,255"
"Colour20"="187,187,187"
"Colour21"="255,255,255"
"RawCNP"=dword:00000000
"PasteRTF"=dword:00000000
"MouseIsXterm"=dword:00000000
"RectSelect"=dword:00000000
"MouseOverride"=dword:00000001
"Wordness0"="0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
"Wordness32"="0,1,2,1,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1,1"
"Wordness64"="1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,2"
"Wordness96"="1,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,1,1,1,1"
"Wordness128"="1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1"
"Wordness160"="1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1"
"Wordness192"="2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,2,2,2,2,2,2,2,2"
"Wordness224"="2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,1,2,2,2,2,2,2,2,2"
"LineCodePage"="UTF-8"
"CJKAmbigWide"=dword:00000000
"UTF8Override"=dword:00000001
"Printer"=""
"CapsLockCyr"=dword:00000000
"ScrollBar"=dword:00000000
"ScrollBarFullScreen"=dword:00000000
"ScrollOnKey"=dword:00000000
"ScrollOnDisp"=dword:00000001
"EraseToScrollback"=dword:00000001
"LockSize"=dword:00000000
"BCE"=dword:00000001
"BlinkText"=dword:00000000
"X11Forward"=dword:00000000
"X11Display"=""
"X11AuthType"=dword:00000001
"X11AuthFile"=""
"LocalPortAcceptAll"=dword:00000000
"RemotePortAcceptAll"=dword:00000000
"PortForwardings"="L8000=127.0.0.1:80"
"BugIgnore1"=dword:00000000
"BugPlainPW1"=dword:00000000
"BugRSA1"=dword:00000000
"BugIgnore2"=dword:00000000
"BugHMAC2"=dword:00000000
"BugDeriveKey2"=dword:00000000
"BugRSAPad2"=dword:00000000
"BugPKSessID2"=dword:00000000
"BugRekey2"=dword:00000000
"BugMaxPkt2"=dword:00000000
"BugWinadj"=dword:00000000
"BugChanReq"=dword:00000000
"StampUtmp"=dword:00000001
"LoginShell"=dword:00000001
"ScrollbarOnLeft"=dword:00000000
"BoldFont"=""
"BoldFontIsBold"=dword:00000000
"BoldFontCharSet"=dword:00000000
"BoldFontHeight"=dword:00000000
"WideFont"=""
"WideFontIsBold"=dword:00000000
"WideFontCharSet"=dword:00000000
"WideFontHeight"=dword:00000000
"WideBoldFont"=""
"WideBoldFontIsBold"=dword:00000000
"WideBoldFontCharSet"=dword:00000000
"WideBoldFontHeight"=dword:00000000
"ShadowBold"=dword:00000000
"ShadowBoldOffset"=dword:00000001
"SerialLine"="COM1"
"SerialSpeed"=dword:00002580
"SerialDataBits"=dword:00000008
"SerialStopHalfbits"=dword:00000002
"SerialParity"=dword:00000000
"SerialFlowControl"=dword:00000001
"WindowClass"=""
"ConnectionSharing"=dword:00000000
"ConnectionSharingUpstream"=dword:00000001
"ConnectionSharingDownstream"=dword:00000001
"SSHManualHostKeys"=""
FreeNAS (192.168.1.20)
  • Edit Lines:
    • (5) "HostName"="root@192.168.1.20"
    • (6) "LogFileName"="C:\\Path\\To\\PuTTY\\Logs\\SSH.FreeNAS.Remote.log"
    • (58) "PublicKeyFile"="C:\\Path\\To\\PuTTY\\SSHkeys\\FreeNAS.SSH.ppk"
  • plink creates the multi-hop
    • (32) "ProxyTelnetCommand"="plink -v -load SSH.OpenWRT.Remote -nc %host:%port"
      • If Router's profile name changed, update it here too
        Profile cannot contain spaces
[HKEY_CURRENT_USER\Software\SimonTatham\PuTTY\Sessions\SSH.FreeNAS.Remote]
"LogFileClash"=dword:00000000
"Protocol"="ssh"
"PortNumber"=dword:00000b83
"ProxyMethod"=dword:00000005
"ProxyHost"=""
"ProxyPort"=dword:00000000
"ProxyUsername"=""
"ProxyPassword"=""
"Environment"=""
"UserName"="root"
"LocalUserName"=""
"AgentFwd"=dword:00000000
"Cipher"="aes,3des,blowfish,WARN,arcfour,des"
"RekeyBytes"="1G"
"GSSCustom"=""
"LogHost"=""
"RemoteCommand"=""
"BellWaveFile"=""
"WinTitle"="Secure Shell - FreeNAS (Remote)"
"Colour6"="0,0,0"
"Colour8"="187,0,0"
"Printer"=""
"X11Display"=""
"X11AuthFile"=""
"PortForwardings"=""
"BoldFont"=""
"WideFont"=""
"WideBoldFont"=""
"SerialLine"="COM1"
"WindowClass"=""
  • Once each profile has been edited, save as a .reg & merge into registry
    • Once merged, you will immediately see them as profile options in PuTTY
Incorporating Existing Profiles
  • Merge FreeNAS profile after editing the profile name on line:
    • (32) "ProxyTelnetCommand"="plink -v -load Remote.Router.Profile -nc %host:%port"
  • Existing FreeNAS Profile
    • Create a copy of it
      • Under Settings - Connection - Proxy - Telnet Command add:
Initiating Multi-Hop
  • Open SSH.FreeNAS.Remote profile
    • If utilizing a password on PKI key:
      • First password request: SSH.OpenWRT.Remote
        Second password request: SSH.FreeNAS.Remote
PSCP commands
  • Push:
    pscp -r -i "C:\Path\To\PuTTY\SSHkeys\FreeNAS.SSH.ppk" -2 -scp -P 22 "D:\Path\To\File.txt" root@192.168.1.20:/path/to/directory
    • Without utilizing PKI
      pscp -r -scp "D:\Path\To\File.txt" -P 22 root@192.168.1.20:/path/to/directory
  • Pull:
    pscp -r -i "C:\Path\To\PuTTY\SSHkeys\FreeNAS.SSH.ppk" -2 -scp -P 22 root@192.168.1.20:/path/to/file.txt "D:\Path\To\Directory"
    • Without utilizing PKI:
      pscp -r -scp root@192.168.1.20:/path/to/directory -P 22 "D:\Path\To\File.txt"
  • -r = copy directories recursively
  • -i = keyfile
  • -2 = -2 (force use of particular SSH protocol version)
  • -scp = force use of SCP protocol
  • -P = connect to specified port
Recommendations
  • GPG4Win
    • PKI & SSL certificate management
    • Seamlessly interfaces with PuTTY & autoloads keys into pageant via Kleopatra
  • WinSCP
    • GUI for transferring files over SSH
    • Explorer like drag & drop
    • Interfaces seamlessly with PuTTY
  • Pageant (part of PuTTY)
    • Best compromise between security & convenience
    • While using, with or without GPG4Win, do not leave PC unsecured
      • Kleopatra will kick you out after ~30 min of terminal inactivity, pageant will not
    • Keeps PKI keys active for a specified amount of time
      • GPG4Win auto loads keys into pageant
      • Pageant only operates on the backend with Kleopatra
  • Load Keys:
    pageant "D:\Path\To\PuTTY\SSHkeys\FreeNAS.ppk" "D:\Path\To\PuTTY\SSHkeys\Router.ppk"
  • Load Key & Start PuTTY:
    pageant "D:\Path\To\PuTTY\SSHkeys\FreeNAS.ppk" "C:\Program Files\PuTTY\putty.exe"
    x64: C:\Program Files (x86)\PuTTY\putty.exe
  • carmorales's HowTo
  • Glorious1's HowTo
Windows 10 Calculator has a "Programmer" mode with built in hex <--> dec
So does the Windows Vista-8.1 calculator. ;)
Interesting guide, in any case.
zoomzoom
Thanks =]
I couldn't remember if Win 8.1 and prior did or not ;) I'll edit that in tomorrow since I've reached the 30,000 character limit and will need to figure out what to reword.
Sent from my NX6 using TapaTalk
Well, just Windows Calculator should be fine. Anyone still on XP deserves to spend 2 minutes looking for that option (and I'm not sure they won't find it).
Bidule0hm
Server Electronics Sorcerer
I know it exists on Seven and I'm pretty sure it is on XP too ;)
zoomzoom
Thanks! =] Windows 10 Calculator was changed to just Windows Calculator :)
zoomzoom
zoomzoom
Does anyone know why this does not work with Sophos UTM when multi-hopping via PuTTY? I can multi-hop through Sophos UTM with JuiceSSH on Android, but am not able to do so on PuTTY.
Gnome
zoomzoom
Sophos UTM doesn't allow for that due to security reasons.
  • Due to Sophos' custom written Confd, even if I manually configured it as a bastion host via cli, the change may last a few hours, a few days, a few weeks, or a few months, but eventually the change will be removed whenever Sophos UTM receives an update that updates Confd, the SSH daemon, the numerous firewall daemons, IPS, or a file required by any of the above (Sophos UTM checks for updates every 15 minutes and usually pulls quite a few updates every week).
I'm not sure I understand the viewpoint of this being complicated... An SSH multi-hop is fairly standard and, generally speaking, quite simplistic. All a multi-hop is is one SSH tunnel through an existing SSH tunnel (essentially a bastion configuration without the bastion host).
  • You may be specifically referring to the How To, and due to the specific options that need to be set in PuTTY (or any SSH client), it may appear more complicated than it actually is.
    • All the HowTo does is set up a remote SSH profile (something that needs to be done regardless of a multi-hop), and add a proxy command to the local SSH profile.
