Howto build and install LMS 7.8 / 7.9 for FreeNAS 9.2.1.6 from scratch
Roger Wilco
Edit by Cyberjock: This guide has been superceded by https://forums.freenas.org/index.ph...build-and-install-lms-7-9-from-scratch.27161/. This thread is locked. Please use the new guide.
I've been reading silently for some time now, and felt like this information might be helpful to someone...
I've set up FreeNAS-9.2.1.6-RELEASE-x64 (ddd1e39) on a HP Proliant Microserver Gen8 and have as evidently many others been struggling with Squeezebox LMS.
I have absolutely no experience with FreeNAS but used to have quite enough experience with FreeBSD during the 2.x - 4.x releases.
So please feel free to comment on all the DON'Ts I did which I am not aware of :)
Anyway, as the howtos for LMS didn't work for me (djoole did a nice job for 7.8 though) I decided to get that thing running from scratch on.
This is a complete step by step howto for compiling and setting up LMS 7.8 / 7.9.0 on a 64-bit Freenas 9.2.1.6. The line numbers are for 7.9.0, so use your editor's search function to find the code blocks for 7.8...
I've used a clean FreeBSD installation inside a VM and a clean FreeNAS installation on the Microserver.
The LMS seems to run nicely, so far I have no open points regarding LMS.
Once again, some of the steps are probably for 64-bit systems only!
Prerequisites
Install a FreeBSD 64-bit inside a virtual machine.
I've used FreeBSD-9.2-RELEASE-amd64-disc1.iso
The alternative to a VM would be to build it under FreeNAS directly which should be quite straightforward too, or if you decide to build it in a jail you'll have to disable the tests (RUN_TESTS=0) in buildme.sh at least for IO::Interface (there is a hardcoded 127.0.01 check in them).
Anyway this is only about building LMS in a VM, so you might have to change some things if you do not use a VM...
Setup networking, create a user
As root in the VM:
vi /etc/rc.conf
sshd_enable="YES"
service sshd start
rm /usr/local/etc/pkg.conf
mkdir -p /usr/local/etc/pkg/repos
cd /usr/local/etc/pkg/repos
touch FreeBSD.conf
vi FreeBSD.conf
FreeBSD: {
  url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest",
  mirror_type: "srv",
  enabled: yes
pkg update
pkg install bash-4.3.18_2
This should not be necessary, but I did it for God's sake...
vi /etc/fstab
fdesc    /dev/fd        fdescfs        rw    0    0
mount -t fdescfs fdesc /dev/fd
FYI, git installs perl5-5.16.3_11 as a dependency.
Check the version, because for 5.16 and above there are additional steps necessary (see below).
pkg install git-2.0.0
pkg install gmake-3.82_1
pkg install rsync-3.1.1_2
pkg install nasm-2.11.05,1
pkg install wget-1.15
As user in the VM:
mkdir ~/some_dir
cd ~/some_dir
git clone https://github.com/Logitech/slimserver-vendor -b public/7.9
cd ~/some_dir/slimserver-vendor/CPAN
vi buildme.sh
At line 49 replace...
if [ ! -x /usr/bin/rsync ]; then
    echo "This script requires /usr/bin/rsync, please install it."
    exit
fi
... with (i.e. the path is not /usr/bin but /usr/local/bin):
if [ ! -x /usr/local/bin/rsync ]; then
    echo "This script requires /usr/local/bin/rsync, please install it."
    exit
fi
vi buildme.sh
At line 1110 replace...
# FreeBSD amd64 needs arch option
    if [ $ARCH = "amd64-freebsd" ]; then
        FFOPTS="$FFOPTS --arch=x64"
    fi
... with (i.e. the architecture-string is wrong (might be in my case only - try without this change first)):
    if [ $ARCH = "amd64-freebsd-thread-multi" ]; then
    fi
vi buildme.sh
At line 306 replace...
    if [ $RUN_TESTS -eq 1 ]; then
        make test
    else
        make
    fi
with (i.e. skip the non-working tests for Font::FreeType 0.03):
        if [ $1 = "Font-FreeType-0.03" ]; then
            echo "Skipping tests for Font-FreeType-0.03"
        else
            make test
        fi
    else
        make
    fi
(Create a tarball as a backup, so I can rm -rf and start over without thinking...)
cd ~/some_dir
tar cf slimserver-vendor.tar slimserver-vendor/
(Copy (pipe output into tee) the build's output on stdout to a log file)
FYI, the build takes in a VM with a Macbook Pro Late 2011 as host about 10 minutes.
./buildme.sh | tee ~/some_dir/buildme.sh.log
On success check the build.sh.log (or don't care).
I've had issues where some packages installed themselves not in the build directory under CPAN
but under a "global" directory in the user's directory (e.g. grep for the username).
cd ~/some_dir/slimserver-vendor/CPAN/build
tar cf ~/some_dir/arch.tar arch/
For Perl >= 5.16 Class-XSAccessor-1.18 is used, otherwise it is Class-XSAccessor-1.05.
In the noCPAN-tarball there is only Class-XSAccessor-1.05, which leads to
"NOTE: Class::XSAccessor 1.05+ not found, install it for better performance" on launch of LMS.
This is because we compile the 1.18 binary module but we only have the 1.05 perl module
in the CPAN directory.
START This is for Perl >= 5.16 only
cd ~/some_dir/slimserver-vendor/CPAN/build/5.16/lib/perl5/amd64-freebsd-thread-multi/Class
tar cf ~/some_dir/xsaccessor118.tar *
END This is for Perl >= 5.16 only
cd ~/some_dir
wget http://downloads.slimdevices.com/nightly/7.9/sc/363b797/logitechmediaserver-7.9.0-1406205019-noCPAN.tgz
Copy all three (or two for Perl < 5.16) files to your FreeNAS-box
scp arch.tar xsaccessor118.tar logitechmediaserver-7.9.0-1406205019-noCPAN.tgz someuser@1.2.3.4:/some_dir_on_freenas
Create a jail throught the FreeNAS GUI
Type: standard
Autostart: checked
VIMAGE: not checked
(NAT: not checked)
Vanilla: checked
As root on your FreeNAS:
jexec the_jails_name /bin/csh
cd /usr/local/
mkdir lms
FYI, UIDs / GIDs info:
I follow this scheme:
1000 < [UG]ID < 10000 are reserved for the host
10000 < [UG]ID < 20000 are reserved for jail with JID=1
20000 < [UG]ID < 30000 are reserved for jail with JID=2
and so on. This way I can immediatelly see who a process/file/... belongs to both
in a jail (name) and the host (UID).
pw groupadd -n lms -g 20001
pw useradd -n lms -u 20001 -g lms -s /usr/sbin/nologin -c "Logitech Media Server" -d /nonexistent
Leave the jail
cp /some_dir_on_freenas/logitechmediaserver-7.9.0-1406205019-noCPAN.tgz /path_to_your_jails/lms/usr/local/lms/
cp /some_dir_on_freenas/arch.tar /path_to_your_jails/lms/usr/local/lms/
cp /some_dir_on_freenas/xsaccessor118.tar /path_to_your_jails/lms/usr/local/lms/
cd /usr/local/lms
tar xzf logitechmediaserver-7.9.0-1406205019-noCPAN.tgz
tar xf arch.tar -C /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/
Rename the 1.05 version (which is not needed for Perl >= 5.16), and use the 1.18 version instead.
mv /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/Class/XSAccessor /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/Class/_XSAccessor
mv /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/Class/XSAccessor.pm /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/Class/_XSAccessor.pm
tar xf xsaccessor118.tar -C /usr/local/lms/logitechmediaserver-7.9.0-1406205019-noCPAN/CPAN/Class/
Delete all three tarballs.
rm xsaccessor118.tar arch.tar logitechmediaserver-7.9.0-1406205019-noCPAN.tgz
mv logitechmediaserver-7.9.0-1406205019-noCPAN/* .
rmdir logitechmediaserver-7.9.0-1406205019-noCPAN
chown -R lms:lms /usr/local/lms
Perl is not installed in the jail (but check it - should be the same version as the one in the VM)
pkg upgrade
pkg install perl5-5.16.3_11
The scanner complains about missing libintl.so.9
pkg install gettext-0.18.3.1_1
Leave the jail
exit
The startup script uses command line parameters to set the
  • prefs
  • cache
  • (playlists)
  • log
directories below /var, i.e. it creates the directories and sets the permissions, so that
the lms process (running as user lms) can use them. Unfortunatelly there is no parameter for
the playlists directory, but one can set it up during the initial setup in the web interface.
cp /where_ever_the_rcd_script_lies/lms /path_to_your_jails/lms/usr/local/etc/rc.d
chmod 755 /path_to_your_jails/lms/usr/local/etc/rc.d/lms
In order to start LMS upon start of the jail:
echo 'lms_enable="YES"' >> /etc/rc.conf
That's it. Here at least, it does work...
[/b]Startup script called lms for /usr/local/etc/rc.d[/b]
#!/bin/sh
# This script is a slightly modified version with hardcoded values of:
# $FreeBSD: branches/RELENG_9_2_0/audio/squeezeboxserver/files/squeezeboxserver.in 302141 2012-08-05 23:19:36Z dougb $
# PROVIDE: lms
# REQUIRE: LOGIN
# KEYWORD: shutdown
# Add the following lines to /etc/rc.conf to enable lms:
#lms_enable="YES"
. /etc/rc.subr
name=lms
start_precmd="lms_start_precmd"
stop_postcmd="lms_stop_postcmd"
rcvar=lms_enable
command=/usr/local/lms/slimserver.pl
command_interpreter=/usr/bin/perl
pidfile=/var/run/${name}/${name}.pid
logdir=/var/log/${name}
statedir=/var/db/${name}
cachedir=${statedir}/cache
prefsdir=${statedir}/prefs
playlistdir=${statedir}/playlists
charset=UTF-8
u=lms
g=lms
command_args="--daemon --pidfile=${pidfile} --logdir=${logdir} --cachedir=${cachedir} --prefsdir=${prefsdir} --charset=${charset}"
lms_user=${u}
lms_group=${g}
lms_start_precmd()
    # This is stuff is here and not in pkg-install because
    # /var/run may be destroyed at any time and we've had issues
    # with permissions on the various directories under /var getting
     # screwed up in the past.
    mkdir -p /var/run/${name}
    chown -RH ${u}:${g} /var/run/${name}
    mkdir -p ${logdir}
    chown -RH ${u}:${g} ${logdir}
    mkdir -p ${statedir}
    mkdir -p ${cachedir}
    mkdir -p ${prefsdir}
    mkdir -p ${playlistdir}
    chown -RH ${u}:${g} ${statedir}
    export LC_CTYPE=en_US.UTF-8
lms_stop_postcmd()
    pids=`pgrep -u $u`
    if [ -n "${pids}" ]; then
        sleep 1
        kill $pids > /dev/null 2>&1
    fi
    pids=`pgrep -u $u`
        wait_for_pids $pids
    fi
load_rc_config ${name}
lms_enable=${lms_enable:-"NO"}
lms_flags=${lms_flags:-""}
run_rc_command "$1"
Sent you a PM. There's aspects of this guide that aren't really applicable to FreeNAS and/or shouldn't be done on FreeNAS. PMed the OP to see if we can get that straightened out. ;)
Stuarty
I followed this guide on nas4free with nightlies drawn from slimserver github and it worked for me. I have LMS 7.9 on nas4free 9.2 with perl 5.16. It didn't make any difference that I was working on nas4free rather than freenas. I disabled all tests in the buildme and carefully moved necessary directories from build to the new install.
Roger Wilco
this was written for FreeNAS (and no, there are no aspects which should not be done :) ). The LMS build-script checks for the presence on rsync (which is present on FreeNAS by default, but not on a vanilla FreeBSD installation I used for building). Check whether it is present on NAS4Free, too, otherwise add it to your jail.
I've never bothered to search why LMS would need it, but it might have a reason...
- Roger Wilco
