flashdrive
 - Apr 2, 2021
since the Veeam Linux client is not useful (no scheduling, not all of the data is being backed up) I am looking for another solution.
PC with Ubuntu should push all the rpool content to TNCore
I have found this but am not proficient enough to set this up:
					github.com
I am struggling with the ssh setup:
Note that this is called a "pull" backup: The backup server pulls the backup from the server. This is usually the preferred way.
Its also possible to let a server push its backup to the backup-server. However this has security implications. In that case you would setup the SSH keys the other way around and use the --ssh-target parameter on the server.
Multiple ideas:
1) get a better Veeam solution
2) get this up and running https://github.com/psy0rz/zfs_autobackup/wiki
3) another tool available for Ubuntu - I have tried to use all the other "backup" related applications in the ubuntu store like the rsync based - to no avail
4) Asigra and other plugins in TNCore... - no idea
5) edit: https://github.com/jimsalterjrs/sanoid
6) other ideas
Home
ZFS autobackup is used to periodicly backup ZFS filesystems to other locations. Easy to use and very reliable. - psy0rz/zfs_autobackup
Multiple ideas:
6) other ideas
