consultant
- Jan 7, 2019
#1
I have an Ubuntu Server being used as a file server (SAMBA) and I want to use FreeNAS as a backup solution. The storage device would be an external RAID Array. Since I'm not running ZFS file system on Ubuntu, what would be the best system architecture for using FreeNAS as a backup. Would I basically installed FreeNAS on the NAS RAID box and then NFS mount the Ubuntu file folder and "pull" the files from the Ubuntu server?
I was thinking it might be better to attached the storage via USB 3.1 so the backup doesn't run over the network, but that would mean trying to treat the Ubuntu file server as a storage device and my knowledge of Linux isn't deep enough to determine if that's even possible. As long as the LAN is fast and not congested, considering I need to give access to the backup file to users via CIFS, I suppose it's okay to do the backup data transfer over the network.
If anyone could confirm the recommended architecture I'd be grateful.
