Hello everyone,
I am looking for some clarification on IOCAGE jails. I have converted all of my Warden jails to IOCAGE and everything is working fine.
I have the following jails created and running,
· SabNZBD
· Sonarr
· Radarr
· Plex (Plexpass Version)
I am trying to find information on how you update each of these items.
If I understand this topic correctly, there is updates to the underlying IOCAGE software that can be performed and I assume is updated with each version of either FreeNAS or FreeBSD (When applicable).
Next, is updating the actual software inside the jails. IE Plex. This is where I am a little confused. Previously I used jails and would just update when the “Update” button appeared. Now I suspect I need to go into each jail and run a command to perform an update. Is this accurate? If so, is there a document or something that shows what that command may be? I have tried looking at various support wiki’s for each app, but all I find is instructions on installation. The only update info is related to Windows.
Thanks.
· SabNZBD
· Sonarr
· Radarr
Thanks.
