MisterE2002
- Sep 5, 2015
I have two systems. The new one is Scale. I want to do data transfer over a separate direct 10Gb cable between the two.
My old system has static 172.16.0.2. My Scale system must have static 172.16.0.3.
All systems have a own LAN NIC with DHCP MAC-reserved IP's: 192.168.1.x
I select the enp2s0 and enter all details.
Afterwards TN gives me two options. "Test and revert". It is also warning the main connection can drop.
And this is actually what happens. I press " test" and i can ping 172.16.0.3 at that point.
But my main connection drops so i can not access the GUI anymore. I assume i should have a "confirm" button. But have can i confirm something without GUI? After some time it reverts the changes.
I do not understand why it is resetting the main NIC. I just add a secondary interface.
