How to setup iSCSI properly?
HolyK
Ninja Turtle
can anyone please make a quick "HOWTO" for properly settings of ISCSI in FreeNAS 8 ?
I'm trying to setup it, but without success :/
Thanks
survive
Behold the Wumpus
HolyK
Ninja Turtle
Thanks, i must overlook this in wiki ... srry. Anyway, i followed the documentation, but i'm getting two errors:
1) When i add a new Target, i get this in console:
My Settings:
2) When i add new Extend, i get this in console:
My settings:
And, when i trying discover/connect (to) created ISCSI, i get "Connection failed" msg
Thanks in advance for any help
ezteok
Any luck? I had this to, it's just because you are allready fired up iscsi while you are still configuring the beast. You can ignore these cause these errors, they will disappear when you got your config right. Or stop iscsi while configuring of course :) But you missing a important section.... You must setup the option "Target / Extents" after you set up a extent and a target... Connect a target to a extent so to speak... In your case it will be 'test - test' so i would change to another target name if i was you...
J
