I'm setting up some apps using the custom app button in Truenas Scale 23.10.1.2, but I do not see anyway to set a PGID or PUID so the app will always run as a root user.
Is there a way to set this that I am just missing?
You set them in the "Container Environment Variables" section of the app's edit sheet. For example "Environment Variable Name" is PUID and "Environment Variable Value" is 3001 (or whatever the ID is)...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
