I have created a user who should only have read-only access to a certain dataset or directory. I have set up an extra read-only SMB share for this purpose.
In addition, I have adjusted the permissions for a dataset to which the above-mentioned user should not have access.
Dataset => Edit ACL => ACL Type: Deny => Permissions => Read
I would then also have to do this for other datasets to which the user should not have access (read or write).
Is it not possible to restrict the SMB shares themselves?
- The user mentioned above should only be able to use the read-only smb-share.
- The read-only share only has access to the desired dataset or directory.
How do I do this? With "Edit Share ACL" in Sharing?
