HOW TO REMOUNT A REPLACED HARD DISK
lexmills09
LAST MONTH, I HAVE REPLACED MY 2 TB NAS DRIVE INTO 4TB, NOW I WANT TO REMOUNT MY 2TB TO RECOVER SOME IMPORTANT FILES. HOW TO REMOUNT IT TO NEW TRUENAS TO GET THE FILES THAT I NEEDED? CAN ANYONE HELP ME?
Samuel Tai
How was your old pool constructed before the replacement?
Samuel Tai
I think the simplest option is to mount your disk on a different system from your TrueNAS server, and then retrieve your files there. Ubuntu 20.04 has native support for OpenZFS 2.0, and you should be able to import your pool there via zpool import -f -R /mnt <name of your pool>.
Samuel Tai
Did you look in /mnt to see if the pool mounted? What does zpool status show?
what about the output from zpool import
