how to recover from USB boot drive failure
SteveW
pretty new guy here...
The USB stick I had the boot file of FreeNAS died. I didn't have a backup,,, yeah, I know. I will be mirroring after this, but that's next.
I have reinstalled FreeNAS, it is up and running, I am able to log into FreeNas via the web interface. I have 5 sata drives, all 2 tb. I read several posts, but never found one that matches my level of stupid. I found reference in this forum, as well as the Guide to system -> auto Import Volume, but when I go into system, I do not see the auto import option.
At any rate, I did go into storage -> volumes -> import volume, and after a few minutes of working on it, it found, and now lists, the volumes that were on my RAID (it was ZFS). But, I want to be absolutely sure I don't do anything from here that will delete the info on those volumes, so can someone tell me what I need to do to set up FreeNAS so that I can access the data on those disks?
I assume I need to re-set up users, do they need to be exactly the same as they were before?
Is there anything in System that I need to do?
I just want to be careful to not setup or make/change any settings that will destroy, or make impossible to access, my data, which thankfully looks like it is still in tact.
Thanks in advance!!!
If not, you'll have to redo permissions.
