During the last year I have ran Freenas as a VM on my Dell r720XD with HBA card in IT-mode. However I want to delete Esxi from my server and then run Freenas directly on the Dell r720XD. I don't have any need for adding additional disks. But I just want to ask the following questions to ensure that I don't mess up. And by the way I have a backup :)
My questions are as follows:
- How should I do this move/migration on the best possible way?
- One of my pools is encrypted with passphrase and encryption key are there special concerns that I should take?
- My Dell r720XD has a dual/mirrored SD-card adapter - can I run Freenas from these SD cards or should I avoid this? And if so what solution should I
- If I save the config file is that everything that I need to save?
- When I import the config file after a fresh install are my pools automatically imported?
- Are there anything else that I should consider before starting the migration/moving?
