How to migrate from two disk stripe volume to one big HDD?
guglez
Hi All,
I have a stripe made from two 1T disks. One disk is going to fail soon. I have one big HDD (3.5T) and I want to migrate the data to it. How can I achieve this?
Thank you!
BigDave
FreeNAS Enthusiast
Assuming you can...
Within FreeNAS, use the larger drive and configure a second pool and copy
the data to the new pool.
But I must warn you that IF your "sick" drive dies at any time going forward,
you will lose your data on the striped pool...
Replicate to the new pool and destroy the old one.
joeschmuck
Old Man
Also, you shouldn't use a single hard drive and hopefully you are aware of the risks.
guglez
I tried to do that. Failed. Here is what I did:
zfs snapshot -r black-wd1t-stripe@full-stripe-snapshot
zfs send -R black-wd1t-stripe@full-stripe-snapshot | zfs receive -Fdvu ext-green-4T
receiving full stream of black-wd1t-stripe@full-stripe-snapshot into ext-green-4T@full-stripe-snapshot
received 45.2MB stream in 2 seconds (22.6MB/sec)
receiving full stream of black-wd1t-stripe/images@full-stripe-snapshot into ext-green-4T/images@full-stripe-snapshot
receiving full stream of black-wd1t-stripe/mmedia@full-stripe-snapshot into ext-green-4T/mmedia@full-stripe-snapshot
warning: cannot send 'black-wd1t-stripe/mmedia@full-stripe-snapshot': Input/output error
Or should I just copy the data with rsync? I'm ok ifsome files will be lost.
joeschmuck
Old Man
Sure, but with two disks striped, the risk is doubled--if either of two disks fails you lose all your data. With a single disk, it's only that one disk that's critical. But, of course, a redundant arrangement is much safer.
joeschmuck
Old Man
Ah, the "odds game". I just watched a movie about odds. It was more on card counting but odds was the scientific driver.
