fw_crocodile
- Apr 8, 2021
first I've to say that the wake on lan functionatlity is working and the issue is not related to hardware/BIOS settings.
I'm using TrueNAS SCALE, so I'm operating on a linux environment.
The wake on lan capabilities of the network card are disabled on boot, probably on driver loading. I've to enable the magic packet before the shutdown if I want to be able to turn it on later by a magic packet (ethtool -s ethX wol g).
There is any place where some settings are applied on the network interfaces where i can add this settings?
Or the only solution is to add a init/shutdown script?
Would it be possible to add it on the network card configuration panel? It seems tthat it's a common problem to have the wol turned off on driver loading.
