How to install git
Ray Milyard
Senior Member
I have a FreeNAS 9.3.x that is up to date as of today.
When I try:
pkg install git
I get this error:
root@sabnzbd_1:/ #pkg: No packages available to install matching 'git' have been found in the repositoriesAll repositories are up-to-date.FreeBSD repository is up-to-date.Updating FreeBSD repository catalogue...
How can I fix this or install git. Sorry but FreeBSD noob here.
D
dlavigne
Guest
Are you running that command inside a jail or from the FreeNAS shell?
Ray Milyard
Senior Member
Inside of my sabnzbd jail. Trying to get Joshua media stuff working. Worked the other day. Now getting that error trying setup friends server.
D
dlavigne
Guest
That's the correct command. Can you double-check that you can ping a domain name (such as google.com) from within the jail?
Joshua Parker Ruehlig
Wizened Sage
I'm assuming the package is broken on the official repo at the moment. you could always try building from ports
cd /usr/ports/devel/git
make install clean
Wizened Sage
you probably need to install the ports tree
portsnap fetch install
m0nkey_
Dedicated Sage
Sounds like your repository's are not up to date.
To update pkg:
# pkg update
To update ports:
# portsnap fetch extract
Ray Milyard
Senior Member
To update pkg:
# pkg update
To update ports:
Did the portsnap fetch extract the cd usr/ports/devel/git and make clean install. Now what?
