how to import a detached volume with status UNAVAIL
ashokmedia
I had a raidz 2by2 configuration,My zpool status changed to UNAVAIL. When i examined my hardware one of my hard disk is failure. After i replaced my hard disk with new one the status remained UNAVAIL. I detached the volume from gui. When I tried to import using shell command zpool import its showing error message "one or more device missing ...". Anyone please help me to repair and import my zpool.
ashokmedia
thanks for your reply
[root@freenas ~]# zpool import
   pool: segate2by2
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://illumos.org/msg/ZFS-8000-6X
        segate2by2                                    UNAVAIL  missing device
          gptid/44dbc0c3-bc42-11e8-b444-001b21240432  ONLINE
          gptid/e2344073-ea0f-11e5-b4ad-001b21240432  ONLINE
          gptid/e2d70637-ea0f-11e5-b4ad-001b21240432  ONLINE
        Additional devices are known to be part of this pool, though their
        exact configuration cannot be determined.
There's no such thing (the closest thing I can think of to that terminology would have traditionally been called RAID 10, and with ZFS is called striped mirrors, but that wouldn't be any flavor of RAIDZ, and also isn't what you had). What you appear to have had was four disks striped, with one of the disks now missing or dead. Unless you can revive that disk for at least a while, your data is gone.
ashokmedia
yes this is how i created
The output of zpool import indicates that you're mistaken. That output indicates that you had three disks (which are available to the system) striped with at least one more (and from the rest of your post, almost certainly exactly one more). You had no redundancy in that configuration, so with the loss of one disk all the data in your pool is lost. The only way to get any of your data back is to bring that disk back online, or to restore from backup.
garm
To get mirrors you needed to select “mirror” in the creation dialogue drop down. You show “stripe” and thus you will create a striped pool, regardless of how many rows of disks you have.
ashokmedia
I already resilvered a disk a year before.So im sure that failure of a disk will not destroy my array.
ashokmedia
Is it possible to change the status of my zpool to degrade and resilver it with a new disk?
Based on what you have shown us, that can't be true... are you sure you resilvered and didn't just add a disk to the pool?
garm
You can resilver a drive in a stripe as long as you don’t have checksum errors, but if you have an unavailable drive and you can’t revive it you lose the pool
As @garm pointed out, perhaps you did resilver by temporarily adding a disk, resilvering a working disk to it (which must work during the process), then removing the working original disk.
Zpool status (which is shown for an unimported pool with zpool import anyway) shows us that you don't have a redundant pool setup, so with a missing disk, you have no options to recover other than your backup (if you have one).
HoneyBadger
actually does care
Administrator
Grab the output of zpool history in one text file, the output of zdb -U /data/zfs/zpool.cache in another, and attach the two text files to a post here.
This will definitively tell you the past and present states of your pool.
ashokmedia
sory for the delay
  • try.txt
HoneyBadger
actually does care
Administrator
sory for the delay
Your zpool history is only showing the freenas-boot pool ... although since the other one is in an exported state that's probably to be expected.
But looking at the zdb output we can see that your pool was indeed created with four striped vdevs. All four disks are directly from the root.
ashokmedia
It's showing only boot because I detached segate2by2 volume. I had only that volume.
