[How-To] Giving Plugins Write Permissions to Your Data
Joshua Parker Ruehlig
Ok, another total noob to FreeNas here. I've created a user Jails that belongs to the wheel group with a UID of 1003. Ideally, I'd like to use Solution 2 so that each jail has access to write to the dataset that's mounted to each jail.
Creating the user inside the jail seemed to work without a hitch. However, when I try to complete the second step in Solution 2 is where I think I'm getting hung up. Here's what the it looks like when I submit the commands. Maybe I missed a step or something?
root@sickbeard_1:/ # service sickbeard onestop
Stopping sickbeard.
Waiting for PIDS: 75222.
root@sickbeard_1:/ # chown -R Jails:WHEEL /var/db/sickbeard
chown: WHEEL: illegal group name
root@sickbeard_1:/ # chown -R Jails:wheel /var/db/sickbeard
root@sickbeard_1:/ # sysrc 'PLUGIN_user=Jails'
PLUGIN_user: Jails -> Jails
root@sickbeard_1:/ # service sickbeard start
Starting sickbeard.
Data directory: /var/db/sickbeard must be writable (write permissions). Exiting.
/usr/local/etc/rc.d/sickbeard: WARNING: failed to start sickbeard
Now I can't even get sickbeard to restart!?
you didnt change the user sickbeard runs as.
in the 'sysrc' step replace "PLUGIN" with "sickbeard"
also in case you have an issue with the pidfile run this..
rm -r /var/run/sickbeard
sdgenxr
Thanks for the help @Joshua Parker Ruehlig, Sickbeard is running once again. However, I cannot get it to have write access. Is there something I'm missing here?
Thanks!
Thanks!
If sickbeard is running as your Jails user, and the UIDs match that of the owner yof that dataset you set outside the jail, sickbeard should have ownership of those files/folders as well.
Can you check what this gives you from inside the jail?
ls -l /path/to/mediafiles
sdgenxr
If sickbeard is running as your Jails user, and the UIDs match that of the owner of that dataset you set outside the jail, sickbeard should have ownership of those files/folders as well.
How do I know if sickbeard is running as the Jails user? When I run "ls -l /media" it returns "total 0".
I really appreciate your help on this! It's been on my list of things to do for over a month now.
you could check using 'ps aux' but I'm pretty sure it is base on your earlier output.
you ran that command in the jail? I have a feeling you ran that in the host.
sdgenxr
Yes, I ran it from the jails tab and selected the shell link at the bottom of the page.
root@sickbeard_1:/ # ls -l /media
total 0
total 0
Ok I'm a bit confused then cause tat folder is empty.
You need write acces to the /media folder, is that where you want sickbeard to organize files too, or where you want sabnzbd/trransmission to download files too? Is that a dataset mounted into the jail?
sdgenxr
Yes, I would like sickbeard to have write access to the /media folder. I currently have "/mnt/Vol_1/Shares/TV Shows" as the storage dataset source and "/media" the destination configured for the jail. Eventually I would like to get transmission et al configured, but I'm working on sickbeard first to figure out how.
Ok, then I need to actually see the permissions on that folder
ls -l / | grep media
sdgenxr
When I run that code, nothing is returned. It just goes back to the command prompt "root@sickbeard_1:/ #"
My mistake, I fixed the code in the post. please try again.
sdgenxr
root@sickbeard_1:/ # ls -l / | grep media
drwxrwxr-x+ 40 1002  wheel    43 Feb  9 15:22 media
drwxr-xr-x   2 root  wheel     2 Jan 12 14:54 mediaTV_Shows
You jail didn't match UID 1002 to the user "Jails". When you created that user in the jail did you specify the UID like in the instructions?
sdgenxr
I noticed that as well. Not sure how it got assigned the UID of 1002. However, when I edit /etc/group it shows that user Jails has the UID of 1003.
Jails:*:1003:
Jails:*:1003:
Looks like you found the issue. I think there's a way to change a users UID. You'd also want to run the 'chown' step again.
sdgenxr
OK, back at this after a fresh install of 9.3. Here's the code I ran and what I get in return for review.
root@sickbeard_1:/ # pw useradd -n Jails -u 1003 -d /nonexistent -s /usr/sbin/no
login
pw: login name `Jails' already exists
Stopping sickbeard.
Waiting for PIDS: 24612.
root@sickbeard_1:/ # sysrc 'sickbeard_user=Jails'
sickbeard_user: Jails -> Jails
Starting sickbeard.
drwxr-xr-x   3 root  wheel     3 Feb 21 20:52 media
At this time, I still cannot add a show in sickbeard as it returns:
2015-02-22 11:03:55 CP Server Thread-4 :: Unable to create the folder /media/TV_Shows/Better Call Saul, can't add the show
login
Stopping sickbeard.
Starting sickbeard.
can you show the output of 'ls -l /media'
sdgenxr
total 12
drwxrwxr-x+ 24 1002  wheel  27 Feb 21 21:05 TV_Shows
total 12
well just like earlier your jail isn't associating UID 1002 with your 'Jails' user. it has a different UID, in your earlier attempt a few posts up you use a different UID (1003)
sdgenxr
OK, my next question is why isn't the correct UID not being associated with the user Jails when created? Just like previously, when I edit /etc/group, it returns Jails:*:1003:.
Here's what I get when read the user information from chpass Jails:
#Changing user information for Jails.
Login: Jails
Password: *
Uid [#]: 1003
Gid [# or name]: 1003
Change [month day year]:
Expire [month day year]:
Class:
Home directory: /nonexistent
Shell: /usr/sbin/nologin
Full Name: User &
Office Location:
Office Phone:
Home Phone:
Other information:
