LaGrandePieuvre
- Aug 13, 2023
I'm planning to build a networked storage system with TrueNas. I'm having a problem finding a SFP+ 10Gb network card compatible and reliable with TrueNas on a single PCI Express 3.0 X4 slot.
My configuration:
Based on a DELL OptiPlex 7060 SmallFormFactor ( Manufacturer's data sheet )
Processor: Intel i7 8700
Ram: 8 Go DDR4 2666MHz
Cache disk: M.2 NVME PCI 3.0 x4 P3 Crucial 1TO
System disk: Crucial BX500 480 GB 3D NAND
Storage disk: In process of purchase
Disk controller: LSI 9207-8i PCIe gen3 x8
Power supply: 200W
My question is: do you know of a network card with at least 1 SFP+ 10Gb port that fits into a PCI Express 3.0 x4 slot?
For my part, I have a back-up if I can't find a suitable card, but I need your expertise, folks. I was thinking of getting an Intel X520-DA1 board, as the model looks robust and is easily supported by TrueNas. This network card has a PCI Express 2.0 x8 connector. However, I only have one PCI Express 3.0 x4 slot. If I connect the card with a PCI Express 3.0 x4 to x8 adapter, I'll have a PCI Express 2.0 x4 connection at 2GB/s (i.e. 16Gb/s) which (i think ?), in terms of throughput, is more than enough to support a 10Gb SFP+ port. My processor can handle 16 PCI Express lanes, 4 of which are taken by the M.2 NVME, 8 by the disk controller, leaving me with 4 free lanes for the network interface.
Do you think this will work?
Will there be any loss of performance on the rest of my PCI Express hardware if I connect my network interface this way?
Do you have any advice on the PCI adapters mentioned above?
Here's my concern, I hope I've been clear enough, I'm new to this, please help me with kindness,
Have a nice day and thank you for your help.
My configuration:
Power supply: 200W
