mikeintexas
- Mar 11, 2013
New TrueNAS user here and I appreciate you sharing your knowledge with me. I have a TrueNAS Scale server that's running great and will soon have a separate TrueNAS Core server (drives are burning in as we speak) that I wish to replicate to.
My setup is very basic, as depicted in the attached diagram.
My core network switch is only a 1GB unit with only SFP ports, no SFP+ available. Both servers are/will be plugged into the switch. However, the motherboards for both systems have SFP+ ports. I'd like to run a DAC between the two systems and replicate over the 10GB connection. Both for speed and to keep that traffic off the core switch.
I haven't actually setup a replication task yet b/c the second system isn't online yet (will be tomorrow) but sifting through the replication wizard I don't see an option to pick a network interface to use. I'm not good with the CLI, but I sure can follow directions if need be. Thanks for any info you can provide.
