Mastakilla
- Jul 18, 2019
Hi everyone,
I'm currently working on replacing my TrueNAS Core system with TrueNAS Scale. My TrueNAS Core system has the legacy encryption on the "pool-level" (I know it's not really on the pool, but it applies to all datasets below) and requires me to enter a passphrase when booting up the system.
I'd like that same kind of encryption (but then the non-legacy equivalent) on my TrueNAS Scale as well, so
1) Requiring a passphrase to be entered at boot
2) Not having to worry about setting encryption for each dataset separately
I tried to set this up like this:
But apparently this sets it up using a keyfile instead of a passphrase (without giving the option to use a passphrase).
And when I want to change this later, I'm running into the following problem:
So what is the proper way of setting up my system dataset with passphrase protection?
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 427, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 465, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/dataset_encryption_operations.py", line 194, in change_key
verrors.check()
File "/usr/lib/python3/dist-packages/middlewared/service_exception.py", line 70, in check
raise self
middlewared.service_exception.ValidationErrors: [EINVAL] id: backuppool contains the system dataset. Please move the system dataset to a different pool before changing key_format.So what is the proper way of setting up my system dataset with passphrase protection?
