How to connect to FreeNas dashboard from internet
embe
Hi, I am quite new to networking and i am wondering if it is possible to connect from outside of the home LAN to FreeNas dashboard (from which i could turn off my machine for example).
I managed WOL working on FreeNas either from Local LAN or from WAN using Asus router dashboard, I also managed portforwarding etc so my Mediabrowser plugin is now accessible form LAN and WAN, but i would also like to turn off FreeNas server when not in use. I tried some steps but no luck. I am connected to internet over PPPOE and i have public IP address. Of course FreeNas has static IP too.
Any idea how to manage turning off remotely?
Thanks
Martin
Jailer
Not strong, but bad
If you must do this, SSH + PUTTY and learn how to use the command line.
embe
Well i just want to remotely turn Freenas server off. Actually i don't need Freenas dasboard if there is a possibility to turn it off from Android mobile phone some other way....
Jailer
Not strong, but bad
Set up SSH on freenas and use the app of your choice. I use WebSSH on my iphone but I don't think it's available for android.
embe
Excellent! So i need to learn how to and will give it a try. Thanks!
