I have received the following error when I run: zpool status -v
Permanent errors have been detected in the following files:
dotsystem/.system/rrd-76c11d7f8a944b3d8e42fe35420dbaa3:<0x97>
Months ago I moves .system to a separate volume named "dotsystem" so that I can spin down the drives. I have had no problems until now.
My main volume, Volume001, consists of three 250GB hard drives in a Z1 array. The main volume is healthy. The dotsystem volume is also listed as healthy. Volume 001 is only used to back up vital work data and files so this volume is not accessed frequently; hence the desire to move .system to the dotsystem volume on a USB and spin down the drives when not being accessed.
Questions:
Is this problem the result of putting .system on a USB drive?
Is the rrd file a log file or folder?
What does the <0x97> at the end of the file mean?
How can I clear this error?
Any recommendations to prevent this error in the future?
Should I have or is it possible to create a Z1 volume of USB drives to hold the .system files?
System Information:
CPU - Intel(R) Xeon(R) CPU E3110 @ 3.00GHz (3000.03-MHz K8-class CPU)
Motherboard - Jetway TI41M
Memory - 8GB system memory
OS - FreeNAS 11 Stable
Boot drive - King Dian SSD 16GB
dotsystem - 32GB USB Drive
Volume001 - 3 250GB Drives in Z1
Questions:
System Information:
