I am using modern small and relatively high resolution lcd monitor as truenas local console monitor. That hardly works:
- only a small part of the screen is used and
- the letters are much, much to small
So I hope there are setting somewhere to change
- the console screen resolution
- to chose a significant larger font size
I know that if the system is up and running for a lot of actions you could use a remote ssh console, but for some actions that is not a good option and you need access to the real local console.
Any option to change that local console in the requested way?
Louis
Louis
