How to autostart nzbget in jail
thimplicity
Hi everyone,
I am new to TrueNAS and installed nzbget into a jail without using the plugin. Unfortunately, I need to execute the command below now every time I restart the jail:
nzbget -D
I have searched in the forum, but have not found a solution proposal that works for me. With just installing the packages, there does not seem to be a service I can just start like proposed here. It would be great, if someone could point me in the right direction.
Thanks a lot!
The answer is right there in your link...
if you installed the pkg, it's as simple as:
sysrc nzbget_enable='YES'
then
service nzbget start
thimplicity
I tried that but receive the following error message:
root@nzbget:~ # sysrc nzbget_enable='YES'
nzbget_enable: YES -> YES
root@nzbget:~ # service nzbget onestart
su: no directory
Have you set the user for nzbget to use?
sysrc nzbget_user='some_user'
