mattlach
- Oct 14, 2012
Hey all,
I'm about to build a new NAS system, and I definitely want ZFSv28, so my plan is to install FreeNAS 8.3 RC1 to set things up, and then upgrade to the final version when it is released. (Can't be long now, right?)
So, before I start, how easy is it to upgrade FreeNAS? Never having used it before, I can only compare it to the other FreeBSD based system I use (pfSense).
Is there an upgrade function built into it, or do I have to upgrade from disk?
When I upgrade does it save all settings, or does everything need to be configured again?
In the opinions of folks here, am I better off waiting for 8.3 Final, or should I be OK getting started with the RC1 version, and upgrading later?
Thanks,
Matt
Thanks,
Matt
