shawly
- Apr 2, 2014
so I've been running OpenMediaVault with three disks and SnapRAID. Since they were formatted with ext4 and FreeNAS can only read ext3, I just reformatted the parity disk as ext3 and gladly all my data fits on this single drive, so I copied all the data on the ext3 drive.
Today my new server board will arrive and I'll install FreeNAS, but now I need to know, how I migrate the data.
I have no fourth disk that could fit the data so I thought, I can create a RAID-Z out of the two other disks and copy all the data from the ext3 disk to the new RAID-Z array and after that I just add the ext3 drive to the RAID-Z as parity drive.
But I guess it isn't that easy, since I need three disks for RAID-Z, right?
Edit: I've read I can create a degraded RAID-Z pool with two disks and then copy the data from the ext3 disk to the pool and then add the third disk after. So it's pretty much what I asked for, right?
