luckyluke699
- Mar 30, 2016
Hello All,
I would like to get OwnCloud accessible externally, and am after a little help achieving:
- Owncloud diverts all http port 80 requests to https on a high port number (e.g. 8080)
- Owncloud is accessible on local LAN via internal IP (e.g. 192.168.0.10:8080), as well as on web via a DDNS address (e.g. LukesServer.ddns.net:8080)
I am comfortable with how to configure the DDNS and router port forwarding. I would appreciate assistance with learning and understanding how to configure the apache SSL access correctly to achieve the above within the jail if anyone can help :)
My Setup:
Freenas: FreeNAS-9.3-STABLE-201602031011
OwnCloud: Plugin - 9.0
System: HP N54L / 16GB RAM
Apache: Apache24
I copied the following to create SSL certificates within the jail:
http://www.stephen-scotter.net/comp...n-please-double-check-the-installation-guides
I then edited the 'httpd-ssl.conf' to alter the port apache is listening to from 443 to 8080 as it mentioned.
Unfortunately after an apache restart I couldn't acccess the web page (no response to :80, :443 or :8080). Just timing out.
Next I looked at the offical https documentation here, which mentions other.different configuraiton needed?
https://doc.owncloud.org/server/9.0/admin_manual/configuration_server/harden_server.html#use-https
I configured 'httpd-vhosts.conf' as below (I presume this is right?) but still no luck. Just timing out still.
<VirtualHost *:80>
ServerName LukeServer.ddns.net
ServerAlias 192.168.0.10
Redirect permanent / https://192.168.0.10:8080/
</VirtualHost>
<VirtualHost *:8080>
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15768000; includeSubDomains; preload"
</IfModule>
</VirtualHost>
Can anyone help point me in the right direction? Did I do anything particularly wrong above?
I'm a little too new with Apache/BSD to be able to work out where I'm going wrong so thanks in advance if anyone can help! :D
My Setup:
Apache: Apache24
<VirtualHost *:80>
</VirtualHost>
</IfModule>
</VirtualHost>
