How can I restore backup from Duplicati?
bpluccas
Hi, I'm trying to restore, but I get "Access Denied". Probably because Duplicati cant write or something inside the iocage dataset.
There is anything I can do?
I'm using TrueNAS-13.0-U4 and Duplicati with jail.
Ps: Backup works just fine.
I think the important thing to understand here is where you're trying to restore to... do you have rights with the duplicati user to that location?
Inside the jail ls -l /restore/location
On the host ls -l /path/shared/into/the/jail/for/the/restore
Also iocage fstab jailname -l might help to see what's mounted or not.
