BlackRockCity
- Nov 22, 2020
When I'm on the same LAN as my truenas core server, I can backup with Time Machine without problems. Time Machine client looks for truenas.local and proceeds to backup automatically. But when I'm remote and connect into the LAN via VPN, the Time Machine sparsebundle doesn't mount automatically. This seems like a DNS issue?
Here is the problem: When I am remote via VPN and I mount the Time Machine sparsebundle manually at the IP address of my remote Truenas server, the Time Machine volume image mounts but Time Machine client on my Mac won't backup to it because it complains that its looking for the hostname Truenas local. But the volume is not mounted as truenas.local it is mounted it as an IP address smb://IPaddress of my truenas-time machine server. Time Machine client shows that the disk is at truenas local in the System Preferences>Time Machine.
FYI I'm running pfSense on my LAN, if the issue has to do with router settings.
