thimplicity
- Jan 6, 2022
Hi everyone,
I will be moving from QNAP to a DIY home server build and I am in the process of choosing the components, which seems to be very easy, as there is not a lot of choices available . My planned setup is:
I will start with 4 drives, but would like to extend to 8 in the future. I would like this build to last 7-10 years without a complete rebuild if possible. I think I will not need more drives, as I will replace them on a regular basis with larger disks anyways. I would like to keep the enclosure as small as possible, so I was not sure whether to set the limit at 6 or 8, but the mATX standard for motherboards seems to be more widespread and also flexible, so I plan to go with that (until someone here convinces me otherwise). I also ask myself the same question as quite some people online: buy a recent CPU or buy an older Xeon from eBay.
My current favorite is the Intel Xeon E5-2650 or something similar, as it seems to be powerful enough for what I want to achieve.
My current hardware choices:
I would also like to be able to extend the build in the future with:
Before I dig deeper into the component choices - am I on the right track when it comes to the CPU type (cores etc) being powerful enough, enough RAM for now and extendability?
Thanks in advance!
- Proxmox as hypervisor
- TrueNAS virtualized
- Windows 10/11 virtualized (used maybe once or twice a month)
- MacOS virtualized (used maybe once or twice a month)
- approx. 10 docker applications in portainer (incl. Plex)
- Plex would need to stream a max. of three 4k sessions at the same time, but this might grow with 8k coming in the next 5-7 years :)
- Case: fractal design node 804
- CPU: Intel Xeon E5-2650
- Motherboards: tbd
- Graphics card: tbd
- 32 GB ECC RAM
- Additional NVMe: Xiwai 4X NVME M.2 AHCI to PCIE Express 3.0 Gen3 X16 Raid Card VROC Raid0 Hyper Adapter|Computer Cables & Connectors| - AliExpress
- 10GBit Ethernet card
- Graphics card
- Additional SATA card
Thanks in advance!
