Guys,
First off I will try to keep this short and I appreciate the feedback. I have referenced your hardware guide/pdf, but of course being a newbie a lot is still over my head. I have built PCs in the past.
Intended useage: Media server/file storage/and probably 1 part-time (occasional use) VM (or docker/container...tbd). I am not expecting transcoding, but we will say one transcode to be safe.
Capacity: Minimum 4 drives + 1 SSD
Budget: Originally I thought approximately $500.00. (before HHD/SSD Purchase) Now after I selected my components below I guess I am closed to $700.
Case: Fractal Design Node 804 (I prefer something bigger than a Mini-ATX, but smaller than the 804).
Motherboard: Supermicro Micro ATX DDR4 - X11SSM-F-O (If I can go cheaper I prefer, but let me know)
CPU: Intel Core i3-6300
RAM: Crucial 16GB Single DDR4 2400 (PC4-19200) DR x8 DIMM
PowerSupply: Seasonic X-650
Not Factored into Cost
HHD: WD Reds
SSD: Re-purposed 500GB Samsung EVO (For Boot/Cache/VM)
I believe this will work as a NAS when built, but is it overkill for my intended usage?
Any ideas on how to reduce the cost?
Any thoughts on a better case? I like the Node 304 and the 804, but I think I want something in the middle/sweet spot.
Thanks for everything!
Nate
HHD: WD Reds
Nate
