Hi all
I have a P5K motherboard with an E2200 core 2 Duo and 6gb RAM connect via a giga ethernet LAN and running 8.0.1 beta 4. I also have 5 disks stripped connected direct to the motherboard (ICH9).
When I copy a large file (8GB or more), I can see in the report page that the memory is not fully used (4.6 gb used) and the processor is running at 100% or close to it. The network throughput doesn't go over 34 mbits/s.
Doing a DD test via SSH I can write at 236 mb/s and read at 330 mb/s. The fact that I can't go over 34 mbits/s and the processor is at 100% shows that the limitation is the CPU ?
I saw a lot of Atom CPU with people saying that they are transferring files at higher speeds. Isn't a core 2 duo a faster CPU ?
By the way I'm using NFS and AFP and the performance is the same during copy.
