Hi guys,
I am experiencing a problem with my FreeNAS installation the past week. The only thing I experienced prior to this, is I had some problems with Sabnzbd in combination with Sickbeard and / or Couchpotato.
For some reason everything was hanging, so I decided to reboot (through FreeNAS GUI), however I noticed on the console (because it wasn't coming back up) a kernel panic. Since then I had a high load and CPU usage continuously.
I included a screenshot after doing the top command:
Can someone tell me what to do and, if possible, how to fix this.
Please mind my knowledge about FreeNAS and FreeBSD (in general) is very limited (still learning).
I don't know what is causing the high load, wel it seems to be caused by Python, but that can mean everything. Other than that I cannot tell what is causing it.
And rebooting it didn't help and leaving the FreeNAS on for several hours still doesn't reduce the load. I didn't have this before.
Also it causes problems when downloading, because to much or an high CPU usage, lowers my download speed to a few KB/s or even 0.
Please advice. Thank you.
